Problem with .ReadIDTag
  • DazBYorks
    • Feb 2008
    • 59
    Re: Problem with .ReadIDTag
    I am using XP Pro, but your post explains why it has *apparently* not worked. It seems OK with VBScript (I should have checked), but I am using PHP, which will be running as the default user, to access the info via COM objects. I have no real desire to elevate the privileges for PHP, so can I add the relevant key(s) in the registry for the default user?
    Daz
      • 44082
      Copy the reg keys from software\illustrate between the branches.
      • DazBYorks
        • Feb 2008
        • 59
        Thanks, we seem to have success
        I exported the Illustrate branch, renamed the keys and imported the .reg file to the default account.
        Daz
        • skohlmey
          • Feb 2008
          • 12
          I think you will have to use VB.NET to do this.
          I think this Microsoft article is relevant to the original issue of Type mismatch when calling dMC.ReadIDTag: http://support.microsoft.com/kb/197956#top
          SYMPTOMS
          When passing a parameter to a COM Component's method in Active Server Pages (ASP), the following error occurs:
          [COLOR="Red"]Microsoft VBScript runtime error '800a000d' Type mismatch [/COLOR]
          Or the value stored in the variable passed to the method is not changed.
          CAUSE
          VBScript will pass parameters to a method by value if the argument's data type is NOT declared as a variant and the parameter is passed by reference if the argument's data type is declared as variant by the method.
          RESOLUTION
          Parameters to be passed by reference to a method should always be declared as a variant data type by the method, while parameters to be passed by value can be declared as any type by the method.
          • skohlmey
            • Feb 2008
            • 12
            This is what my COM object browser say the definition of ReadIDTag method is:
            Sub ReadIDTag(File As String, Index As Long, pRetElement As String, pRetValue As String)
            If I understand the MS article, I think the definition must be changed to:
            Sub ReadIDTag(File As String, Index As Long, pRetElement As [COLOR="red"]Variant[/COLOR], pRetValue As [COLOR="Red"]Variant[/COLOR])
              • 44082
              #21
              VBScript only have Variant data types, passing a variant would be wrong as the scripting code is expecting an OLE string.
              • skohlmey
                • Feb 2008
                • 12
                #22
                I'm just repeating what MS says on topic. Passing a variant should not prevent a well-written method to check the appropriateness and reasonableness of the data passed to it. I am not sure how to interpret your answer. Does this mean that dMC is not compatible with VBScript? If so, that might be important for some customers to know before purchasing.
                  • 44082
                  #23
                  That one function is not, we will be writing a new method for R13.
                  • skohlmey
                    • Feb 2008
                    • 12
                    #24
                    Thanks for the quick response. I look forward to R13. In the meantime, I have gotten tons of value and had fun using R12.4. It has helped me clean-up a number of issues with my music library already.
                    • aamitabh
                      • Sep 2010
                      • 19
                      #25
                      Has anything changed in R14? I have Windows 7 x64 running on Intel Core i7 (shows as 8 cores). But ReadIDTag does not return any value on 64 bit platform, although it works well on a 32 bit windows 7 platform.
                      I compiled the code inseveral different ways on Windows 7 box:
                      1. CPUAny, on 64 bit Windows 7 - does not work
                      2. CPUx86, on 64 bit Windows 7 - exception on dMC creation, of course
                      3. CPUAny, on Windows 7 32 bit - works
                      What gives?
                      Here is the sample code:
                      Code:
                      DMCSCRIPTINGLib.Converter dMC = new DMCSCRIPTINGLib.ConverterClass();
                      for (int i = 0; ; i++)
                      	string Element = "", TagVal = "";
                      	dMC.ReadIDTag(srcFile, i, ref Element, ref TagVal);
                      	if (Element.Length == 0)
                      		break;
                      	Console.WriteLine("\tReading Tag[{0}] '{1}:{2}'", i, Element, TagVal);
                      	dMC.WriteIDTag(destFile, Element, TagVal);
                        • 44082
                        #26
                        I can see why it is not working in x64, will address for R14.1
                        • chrisjj
                          • Nov 2008
                          • 300
                          #27
                          What is the new method to replace ReadIDTag, please? In R15 the only other I see is ReadIDTagElementValue, which returns a combined string.
                            • 44082
                            #28
                            It was .ReadIDTagElementValue
                            These functions have always returned multi artists combined.
                            • chrisjj
                              • Nov 2008
                              • 300
                              #29
                              OK, thanks.
                              I was referring to the combination of Element and Value. Which is OK... until the separator crops up inside Element
