m4a Nero (AAC) encoder problem
  • stonedowner
    • Aug 2006
    Wonder if anyone can help. I had a script whilst using version 11.5 dbPowerAmp Music Coverter that duplicated a directory structure containing mp3, aac and mp4(apple lossless), converting the apple lossless files to aac file.
    I have now upgraded to V12 and the script stopped working. I found I had to pay £20 for the software and modify the script to use dMC.Convert(). I get the script to run using dMC.Convert("File", "NewFile", "mp3 (lame)", "") but when trying to use "mp4 Nero (AAC)" I get the following error: CLI Encoder is not specified.
    Any ideas?
    Re: m4a Nero (AAC) encoder problem
    Open CD Ripper, set the settings you want for Nero AAC (note the profile name), then look in the registry:
    HCKU\software\illustrate\dbpoweramp\cdripper\profi les\([profile name]\
    and use the command line with Nero in the name.
    • stonedowner
      • Aug 2006
      Thanks for the quick response.
      the line I pulled out of the registry was :-
      -cli_encoder="C:\Program Files\Illustrate\dBpoweramp\encoder\neroAacEnc.exe " -cli_cmd="-q .45 -ignorelength -if - -of [outfile]" -selection="0,4,0,0"
      the command I'm wanting to use in the script is:-
      Call dMC.Convert(File, Destination, dMCCodec, "", "c:\error.txt")
      I'm not sure how to "shoe horn" it in ???
      Hoping you can help
        Call dMC.Convert(File, Destination, dMCCodec, "-cli_encoder=""C:\Program Files\Illustrate\dBpoweramp\encoder\neroAacEnc.exe "" -cli_cmd=""-q .45 -ignorelength -if - -of [outfile]"" -selection=""0,4,0,0""
        ", "c:\error.txt")
        I forget VB programming, so it might be """ instead of "" above.
        • stonedowner
          • Aug 2006
          That did the job. The scripts running like a charm.
          Thanks :komisch12
