scripting problem.. cannot convert from wav to wma
  • pchung
    • May 2007
    Im having problems with my script. I can convert from wav to mp3 without any problem but I cannot convert from wav to wma.
    Here is my script
    Dim dMC
    set dMC = CreateObject("dMCScripting.Converter")
    call dMC.Convert("C:\file.wav","file.wma", "Windows Media Audio 10", "-settings=128 kbps, 44 kHz, 2 channel 16 bit CBR", "C:\dMC_erros.txt")
    set dMC = Nothing
    The -settings cam from the registry.
    I had to remove the double quotes after the -settings=
    I recieve the following error
    Error Creating WMA Profile. [clEncoder::BeginConversion]
    Phil
    Re: scripting problem.. cannot convert from wav to wma
    Moved to Developer section of this forum.
    Have you looked at the code examples from here: http://www.dbpoweramp.com/developer/...0vb%20.NET.txt ? Also, check the WMA help file for scripting settings for WMA.
    • pchung
      • May 2007
      Hi LtData,
      Yes Ive read both docs. but there are'nt any specific examples for wma. Im pretty sure its just a syntax error.. or typo. I am able to convert to mp3.
      Are there any other scripting docs? Do you have a sample of a script that converts to wma?
      Phil
        There aren't specific examples for WMA, no, but it tells you how to set up a script for mp3/wav and then the WMA help file tells you how to set up the command line, which is the same setting for a script, it looks like.
          • 46228
          You would need a " with settings so it is sent as -settings="....."
          • MiHiR
            • Jun 2007
            Hey try using this instead:
            call dMC.Convert("C:\file.wav","file.wma", "Windows Media Audio 10", "-codec={qt}Windows Media Audio 9.2{qt} -settings=128 kbps, 44 kHz, 2 channel mono CBR", "C:\dMC_erros.txt")
            this should work fine.......I've fiddled a lot with it and have got it working, but I'm calling it through command line!!!
            Make sure you have this WMA codec installed:
            Cheers,
            MiHiR
