dMCScripting - Rightclick, Volume, ID3: Title, Author, Copyright and Licensing
  • johntynan
    • Aug 2006
    I have been asked to enfore a certain level of quality for MP3 files for our web site. So I thought I would write the following script in vb6 (see below). In particular, the resulting mp3 files need to match these settings:
    • Codec: MP3 (LAME)
    • Channel: Mono
    • Bit Rate: 64 kbps
    • Encoded Sample Rate: 44.1 kHz
    • Resolution: 16 bit
    • Audio files should maintain a consistent level of -6dB with peaks not exceeding -1dB
    My questions are these:
    1. Is it possible to right click on a file within windows, select an option to "encode audio for web" then pass the drive, path and filename to the dMCScripting component for use with its AddFromFile method?
    2. In addition to normalizing, is it possible to raise the peak volume to -1 dB?
    3. is it possible, via dMCScripting, to display a dialog box for including the title and author in the id3 tag?
    4. is it possible, via dMCScripting - and without any user input, to automatically include a standard copyright and creative commons licensing information in the id3 tag as well?
    Thanks for any suggestions you might have.
    John T.
    Code:
    Private Sub Command1_Click()
    ' Create dMC Object
    Set dMC = CreateObject("dMCScripting.Converter")
    ' Create Mp3 Object
    Set Mp3Settings = CreateObject("dMCScripting.Mp3Settings")
    ' Set Option (Volume Normalization On)
    dMC.VolumeNormalize = True
    ' Set Option (ID Tag Preservation On)
    dMC.PreserveTags = True
    ' Set Option (Do not delete Source files)
    dMC.DeleteSourceFiles = False
    ' Convert To Same Folder As Original
    dMC.ConvertToFolder = False
    ' Set Output Folder (to C:\Converted Music )
    ' dMC.ConvertToFolder = True
    ' dMC.ToFolder = "C:\Converted Music"
    ' Add My Files to Convert
    Call dMC.AddFromFile("C:\Converted Music\AudioFile1.wav")
    Call dMC.AddFromFile("C:\Converted Music\AudioFile2.wav")
    ' Set Mp3Settings: 64kbps  44.1Khz  Mono  CBR
    Call Mp3Settings.Set(64, 44100, 1, 0)
    ' Convert To MP3 (No option page, Want Overwrite page, Want finished, Want Errors)
    Call dMC.GoConversion("Mp3 (Lame)", True, False, False, False)
    ' Convert To Wave (No option page, Want Overwrite page, Want finished, Want Errors)
    ' Call dMC.GoConversion("Wave", True, False, False, False)
    End Sub
    Last edited by johntynan; August 02, 2006, 11:06 PM. Reason: wanted to change subscription settings
    • 46164
    Re: dMCScripting - Rightclick, Volume, ID3: Title, Author, Copyright and Licensing
    a) Yes, you need to know VB scripting well
    b) no
    c) no
    d) yes if you include a dsp effect set id tag
