WMA Conversion (with scripting)
  • KJim
    • May 2006
    • 36
    I know there are a few threads already covering this, but I've tried everything suggested with no results.
    I'm using the following code:
    Set dMC = CreateObject("dMCScripting.Converter")
    dMC.VolumeNormalize = False
    dMC.PreserveTags = True
    dMC.DeleteSourceFiles = False
    dMC.ConvertToFolder = True
    dMC.ToFolder = "C:/Converted Music/"
    Call dMC.AddFromToFiles("sourcefile.aif", "destinationfile")
    Call dMC.GoConversion("Windows Media Audio", True, True, True, False)
    I've installed, reinstalled, restarted at all the right points, converted successfully using the normal interface method, but I can't get it to convert using the script. It just says "Unable to create compression CODEC 'Windows Media Audio', please check software installation."
    Help!!
    • 46065
    Re: WMA Conversion (with scripting)
    Call dMC.GoConversion("Windows Media Audio 9.1", True, True, True, False)
    might help
      Moved to the Developer Forum.
      • KJim
        • May 2006
        • 36
        I tried that edit- no effect I'm afraid...
          • 46065
          The name of the codec as to be identical to the one shown in dbpoweramp, also do one conversion (with WMA) before hand in dbpoweramp.
          • KJim
            • May 2006
            • 36
            Great stuff- that solved it! The name of the codec in the config file was "Windows Media Audio V9"
            Thanks!
