Drive not ready error
  • jdbj
    • Dec 2005
    I downloaded the trial version of CD writer. I am trying to burn a CD from audio tracks on my PC. When I select burn it starts for about 2 seconds and then gives me an error message: CD Drive Error "The drive is not ready". After that my cd drive locks ups, I cannot open it, I have to reboot my computer. I know that my drive works as I can burn a CD with iTunes. Any suggestions?
    Operating system: XP, SP2
    Drive: Plextor DVD burner
    Disks: I have tried music and data 80 min disks.
    Re: Drive not ready error
    Do you have 2 drives? did you select the proper drive?
    • jdbj
      • Dec 2005
      Yes, I do. Yes I selected the correct drive, that is the one that is locking up.
        • 46177
        There could be another program interfering with the CD drive, for example iTunes installs a low level CD burning service that runs even when iTunes is not.
        • sylvainp
          • Sep 2006
          • 15
          Well I also have a Plextor PX-716A (firmware V1.10) and i'm having the same problem.
          It's start to write for about 2 seconds and then I have a window saying that the drive is not ready. After that the CD is scrap and I cannot open the tray door. I need to reboot to make the drive working again. I have tried another burning program with no problems. So my drive is OK
          I have iTunes 7 installed.
          What drivers is this program using ?
          Anyone else using itunes 7 and this software to be working ?
            • 46177
            It uses its own writing component, not drivers. iTunes installs various cd writer components which are used all the time, even when itunes is not running.
            • sylvainp
              • Sep 2006
              • 15
              You have already mention this in this thread that iTunes installed drivers.
              Why this program can't burn CD if using it's own engine ? When we use a PC it is often that we install different burning program and most of the time I never had problem writng CD with everyone of them.
              I have download the trial version because I had some .flac file that I wanted to burn audio CD.
              This software was looking good an easy to use but it is just not working for me. I have an iPod so I will not uninstall iTunes just for this program.
              By the way, iTunes is so popular that I don't understand why the creator if this program has incompability with iTunes.
              I just hope that it will be a fix for this so I could try this software 100%.
                Why should he adjust his software if the software that is causing problem is not behaving properly? Yes, iTunes is popular but also, from what I've heard, a little overzealous regarding your computer.
                • Alstair
                  • Oct 2006
                  Same problem with drive not ready error. Have Itunes 7 installed (latest version). Does not write anything to the disk when this error occurs.
                  :confused:
                    • 46177
                    Try uninstalling itunes.
