Strange Problem
    Re: Strange Problem
    If you could send both of those files to me (one tagged with Amazon US, other UK):
    • prisca
      • Jul 2003
      • 12
      Re: Strange Problem
      On their way - thanks.
      Prisca
        Re: Strange Problem
        Thanks will look asap, I have a few other priority bugs to look into so it is about 4 on the list.
        • prisca
          • Jul 2003
          • 12
          Re: Strange Problem
          Hi Spoon
          I've been doing some more experimenting. The problem is definitely connected to the comment field in the tags. Some texts installed are ok and others mess up the file to give the reported error. I don't really understand how tags work, so I'm only speculating, but I would hazard a guess that there is a size limitation in the comment field which has been exceeded. Renaming files using the Amazon.co.uk site without filling in the comment field results in error free files, whereas filling in the comment field gives the error when trying to convert them.
          Anyway, this might give you a place to start.
          Thanks for your interest. I fully understand that this isn't a priority.
          Kind regards
          Prisca :smile2:
            Re: Strange Problem
            Thanks, it looks like there could be a possible bug in the way it handles large comment fields.
