burner speed
    burner speed
    I have a 48x burner, but the only options listed on the CD writer are 1x, 2x and 4x. How do I burn at the full speed of my drive?
  • Wayne
    • Aug 2002
    • 1254
    Re: burner speed
    What is the maximum recommended speed for the CDR/RW you are using? This could have a bearing on the maximum speed you can use.
    I have also noticed that some CD writer software will not allow a speed greater than x4 if there isn't a disc in the drive at the time you select the speed.
    Wayne
      Re: burner speed
      My 32X burner wll only burn at 4x on CD-RW (this is normal) and 32x on CD-R
        Re: burner speed
        OK, thanks, I think you're right that it might be the media itself, it was an RW disk. I'll try some other disks. Thanks
