Eject problem when burning CDs...
  • wpauge
    • Jul 2009
    • 8
    Hi, first time poster with a quick question. I am using a PC with Windows XP Service Pack 3 and I am burning CDs from AIFF files on my hard drive. I burn the CDs successfully and the problem that I am having is that the CD will not eject. Anyone know what is causing this. When I rip using CD Ripper the CD automatically ejects when the ripping is finished. I am using two diffrent optical drives, one for ripping and one for burning. When the drop down box asks whether I want to eject Cd after burn, I have tries both ways and CD will not eject. I am confused.
    Bill.
    Re: Eject problem when burning CDs...
    You can eject manually with the CD drive button?
    • wpauge
      • Jul 2009
      • 8
      The CD drive button does not operate when after I burn the CD with CD Ripper and the eject button in the program will not eject the CD manually..
      • Specialisa
        • Apr 2012
        nothing else
        how do you do?
        • oneonesip
          • Feb 2013
          Bill.
          I also have have same problem, when eject manually also donot work
