Help Using CD Writer For 1st Time
  • musicmafia
    • Jan 2008
    • 51
    have used plenty of other disc writing programs but my first time with cd writer and i cant figure out how to add tracks! i see no file explorer. nothing. ive tried hitting create, burn, etc but nothing seems to open the file explorer so i can add tracks. PLEASE tell me what i am doing wrong. thanks
  • musicmafia
    • Jan 2008
    • 51
    Re: Help Using CD Writer For 1st Time
    ps i have version 4
      • 46164
      You can do it from Explorer, right click on a track you want to add >> Convert To >> Audio CD
      or drag and drop a file on to the CD Writer Window, or the browsing section on the right of CD Writer, click the <-- arrow to add to CD Writer.
      • musicmafia
        • Jan 2008
        • 51
        sorry, that is what i was trying to say...i can not see or open a browsing section on the right side of cd writer...the tutorial shows the two boxes on the right side but my cd writer has nothing on the right side...is there a trick to opening that browsing section or are you supposed to see it when you open the program because i cant see it? thanks for your help.
          • 46164
          Perhaps your screen resolution is not high enough?
          • musicmafia
            • Jan 2008
            • 51
            no thats not it....is there a way i can send you a screen shot?
              • 46164
              Have you ever seen that section? if you dragged the page to a lower resolution screen then the resizer might be stuck at the far right, try maximising CD Writer, then move the mouse to the right side of the screen, if the mouse changes to a horizontal sizer, you can drag it back on screen.
