Very Slow Encoding Speed
  • NikonUser
    • Dec 2010
    Hi there,
    I have just started using the dCW to burn my flac files to CD.
    However this process seems VERY slow. It encodes at only 4x.
    I have an Intel Q6600 CPU with 8GB ram. When using the CD ripper and other db products it encodes MUCH quicker.
    EDIT: When I convert from FLAC to WAV using dbConverter (which is I assume what the cdWriter is doing?) I get an encoding speed of around 160x
    Is there a setting somewhere I am missing?
    Paul
    • 46220
    Re: Very Slow Encoding Speed
    The actual CD writing is dependant on CD writer drive speed.
    • NikonUser
      • Dec 2010
      It's not the writing speed that is slow, but the encoding speed when it converts from flac to wav in preparation for burning.
        • 46220
        The frequency of the source file is 44.1KHz and 16 bit 2 channel?
        • NikonUser
          • Dec 2010
          Yep. Just a standard FLAC file made from a CD.
          In DbPoweramp Converter the same file encodes to .wav at around 140x
          Also, when using the CDWriter to encode the flacs...CPU utilization is very low. Around 3%
          Paul
            • 46220
            Sorry I have no idea why it is running slow on your system.
            • mtreloar
              • Jan 2011
              • 16
              Same problem. I have Reference Version 14 and an Asus G73Jh quad core w lots of memory. Very fast on encoding to FLAC. All 8 cores used. Desperately slow going from FLAC to audio (not data) CD. Nero does it in 2 minutes or less.
              • mc_frink87
                • May 2002
                +1 - Same problem. CPU usage on my Q6600 stuck at ~4%, with antivirus disabled. Can't seem to work this one out... :confused:
                • etjw
                  • Feb 2010
                  I have this same problem since upgrading to R14. If I am lucky it will encode at 2x. Unusable!
                    • 46220
                    Previously you were using which version (which presumably was fast)?
                    • pfeerick
                      • May 2008
                      • 15
                      Sorry to double-post (previously posted under CW Writer v3.2 beta release thread), but this is the same problem I was reporting there... Namely, I'm running CD Writer R3.2 on Windows 7 Professional SP1 with the 18-MAR-2011 release of dBpoweramp R14.1 beta, and it's taking a long (longer than normal conversions) to convert files to the temporary format (wav?) needed by CD Writer... it's using almost no CPU on a i5 with 2 cores (4 with hyper-threading), and taking 30ish seconds (about the time taken to encode an entire 20-25 track album, let alone two tracks) to transcode two mp3s ?!
                      Screenshot here
                      Also two questions... when erasing CD-RWs, will you be adding the option to quick erase as well as current default of full erase? And am I right in presuming that CD-TEXT is still not supported?
                      -Peter
                        • 46220
                        >not supported?
                        It is not currently planned to add these
