Dynamic naming with unique sequential numbers?
  • slake
    • Sep 2021
    Hello, my colleague and I are using Batch Ripper with a Nimbie NB-21 to rip homemade audio CDs that are part of archival collections. We disabled the metadata providers because these are not commercial recordings (often interviews) and we want to provide our own metadata. To prevent it from overwriting the tracks, we used a dynamic naming string that we found on this forum:
    [IFVALUE]album artist,[album artist],[IFCOMP]Various Artists[][IF!COMP][artist][IFEQUALS]artist,Unknown Artist, [cddb_id][][][]\[album]\[track] [artist] - [title]
    This works to prevent it from overwriting, but we are a little confused about the CDDB_ID value--what exactly is this referring to? How is the ID assigned?
    We are wondering if there is a way to modify this string to incorporate a sequential number into the name instead of the CDDB_ID so that we can easily keep track of which folder corresponds to which CD.
    Thank you in advance for your help!
    • 46218
    Re: Dynamic naming with unique sequential numbers?
    Use [discunique] instead
    • slake
      • Sep 2021
      Thank you so much for your advice, the naming string you suggested worked! Now we have a couple of questions about embedded metadata/tags in the resulting wav files:
      1. Does CD Ripper have a way to capture the date that a CD-R was burned in the metadata?
      2. Is it possible to edit the settings for automatically-generated embedded metadata/tags (e.g. in the "title" field, we would rather have it blank and add our own metadata if needed, rather than "Untitled track 01")
      Many thanks again for your help!
        • 46218
        1. No that information is not in an audio cd
        2 You can use the DSP effect 'Read Metadata File' to replace those values, or ID Tag processing to delete all tags.
