2xNimbie NB21 same PC - Discs not dropping
  • muppetgeoff
    • Dec 2020
    Hoping someone can help. I have 2xNimbies connected to a PC, USB3, no hub.
    According the the BatchRipper page:
    multiple Nimbies can be used on the same machine for commercial ripping.
    If I power up both drives, I see them in Batch ripper (both configured as 'Nimbie'; but starting a rip just hangs batch ripper (not windows). The drive goes in and out a few times, but the discs don't drop. Stopping the batch doesn't do anything and the only way to quit is to kill the process in task manager.
    I've read a few threads with similar issues, but none of them had a solution.
    Batch Ripper configuration is set to 'Nimbie' but the tests hang (and have to be killed by Task Manager).
    Here's the kicker - Everything works perfectly if I turn one of the Nimbies off - either one, it doesn't matter.
    So any ideas what I might be doing wrong? A trick somewhere that I missed?
    In the morning I'm going to uninstall *everything* and start from scratch.
    Many thanks in advance,
    Geoff
    Last edited by muppetgeoff; December 06, 2020, 07:40 AM. Reason: iOS jacks up quotes *sigh*
    • 45441
    Re: 2xNimbie NB21 same PC - Discs not dropping
    We have tested 4 at the same time, although that was a while ago (Windows 7). They were on Dell PCs. If there is a block then it would be easier to add a 2nd computer to control the other robot, even laptop would do.
    • muppetgeoff
      • Dec 2020
      Thanks for the response Spoon.
      I removed everything and reinstalled from the beginning. I also left things alone and gave it as long as it wanted (I started a test and had a shower, started a rip and went out for a while).
      Everything seems to work now, eventually. When I start a rip process, Batch Ripper sits at "Pre-Batch Action" for nearly 3 minutes (@2:40) before proceeding to "Loading CD", then the drive comes in and out a few times before eventually loading a disc after another 9 minutes (@12:40). Rinse and repeat for each CD.
      This only happens when both are plugged in and powered on. With a single Nimbie, it's all very fast.
      I'll keep digging. The Nimbie diagnostic tool works just fine - loading and unloading discs without any delay or other issues.
      The Batch Ripper configuration tests have a similar issue to Batch Ripper itself, in that the tests take an age to run, but eventually do so without any issue.
      So my question is what is the "Pre-Batch action", and is the loader possibly using an incorrect load command (I did note it is blank in the Batch Ripper Configuration)
      Geoff
      • muppetgeoff
        • Dec 2020
        Thanks for the reply Spoon.
        Today Inset a batch running and went out. When I came back it was done. So I re-ran it to see - It takes 2:40 to proceed from "Pre load action" to "Loading CD", then @12:40 it loaded the disc. Rinse and repeat for each disc.
        So it certainly looks like it won't run 2 at once in Windows 10.
        I&*8217;m going to set up a laptop to run the second ripper, and Remote Desktop to manage the first. It&*8217;s a shame Hyper-V and Windows Sandbox don&*8217;t support USB passthrough.
        If anything obvious springs to mind, I'm happy to try it. Otherwise I'll just roll with 2 machines.
        Thanks!
        Geoff
        With a single loader powered on, it works just fine.
        • muppetgeoff
          • Dec 2020
          Well - my grand plan to use RDP to control the Rip PC fell at the first hurdle. As soon as I connect the RDP session, the Nimbie goes offline and I cannot select it in the configuration. It's as if it's been unplugged, but it still shows up in Device Manager.
          Looking like I'll be using a KVM. Ugh.
          *EDIT* Thanks to https://www.google.com/amp/s/nuxx.ne...-workflow/amp/
          In order to use either dBpoweramp CD Ripper or Batch Ripper via Remote Desktop, the following group policy must be enabled: Local Computer Policy &*8594; Computer Configuration &*8594; Administrative Templates &*8594; System &*8594; Removable Storage Access &*8594; All Removable Storage: Allow direct access in remote sessions. This setting is detailed in this article from Microsoft.
          • muppetgeoff
            • Dec 2020
            My final solution (for various logistic reasons) is to run 2 PCs, each with one Nimbie. Then use a Laptop with a tabbed RDP client, so I can display them side by side.
            Thanks for RDP GPO hint Spoon!
            • Rudj
              • Jan 2009
              • 35
              Hi, I read somewhere that there's a special driver for multiple NIMBIES...But there was a long time ago
