Problem installing Batch Ripper
  • smilemakr
    • Aug 2019
    In attempting to install Batch Ripper on my Windows 10 laptop, I'm confronted with the following error notification:
    dBpoweramp_Batch-Ripper-Nimbie (1).exe - Entry Point Not Found
    The procedure entry point GradientFill could not be located in the dynamic link library C:\Users\smilemakr\Downloads\dBpoweramp-Batch-Ripper-Nimbie(1).exe
    Any ideas on how to fix this so I can complete the installation? Thanks.
    Mark
    Re: Problem installing Batch Ripper
    This is a standard API function which has been present since Windows 2000:
    If this is missing your Windows is potentially broken.
      Try running a system file check and/or a dism health check on your laptop.
