Primera Bravo Pro drives not located... help!
  • peachus
    • Apr 2016
    I purchased new last evening, loaded all files, ran as administrator, and cannot get Primera Bravo robot containing drives to be located. Please help or how do I get a refund if the Primera Bravo Pro is not supported? It is on your list as a supported item.PT Publisher works just fine. Please advise.
    Re: Primera Bravo Pro drives not located... help!
    When configuring the loader to the Primera drivers, you can try test load and unload, what messages are shown in the displayed log?
    • peachus
      • Apr 2016
      Errors from testing:
      Unable to locate Primera robot containing drive 'H', please check connection.
      Debug Output:
      Running Program: "C:\Program Files\dBpoweramp\BatchRipper\Loaders\Primera\UnLoa d\UnLoad.exe" --drive="H" --logfile="C:\Users\peachus\AppData\Local\Temp\dBB19 55.tmp" --passerrorsback="C:\Users\peachus\AppData\Local\Tem p\dBB1956.tmp"
      Running...
      Primera Looking For Drive:H
      Primera PTRobot_Initialize: EnumRobots: EnumDrives Robot *0: *** Error: Unable to locate Primera robot containing drive 'H', please check connection.
      PTRobot_Destroy: Destroyed
        Drive H is the primera?
        • peachus
          • Apr 2016
          Yes, it is one of the Primera Bravo Pro drives.
            Try one of the other drives please.
            • peachus
              • Apr 2016
              Yes, I have tried both drives, both have the same result... please advise. Windows 7 Thank you.
                Try right click on the Batch Ripper configuration icon >> Run as Administrator
                • peachus
                  • Apr 2016
                  I did try Batch Ripper config run as administrator and received the same result. Is it possible to get a Mac trial to see if it works? So far, the $39 PC version has not served me at all. Thanks.
                    There is no batch ripper for Mac.
                    • peachus
                      • Apr 2016
                      Hello: Is there more support? What other things can I do to get this working? You say BravoPro is a supported ripper. Please advise.
                        Please forward your order number:
                        For a refund.
