using batchname in output path
  • El Chuck
    • Jun 2025
    According to documentation here (https://www.dbpoweramp.com/Help/Batc...r/options.html) "the output path the following naming variables can also be used: [batchname] [batchid]"
    However when I give a batchname of "Test" with batchid (5001) and set the following path [artist]\[batchname]\[track] [artist] - [batchid] - [batchname] [title]
    The output contains literal "[batchname]" and "[batchid]" like so:
    Code:
    Test Artist\[batchname]\01 Test Artist - [batchid] - [batchname] Track01.mp3
    Am I using this incorrectly? Is the documentation outdated/wrong? Is there a way to get it to work?
    • 46231
    You are ripping CDs with Batch Ripper, not converting audio with Batch Converter?
    • El Chuck
      • Jun 2025
      I am ripping with batch ripper, yes.
      I also found a solution...
      Using "[tag]batchname[]" correctly inserts the batch name into the file path.
