Is there a way to control how long Batch Ripper will try to read a track?
  • pcascio
    • Dec 2015
    I just had one where more than 15 minutes were spent trying to read a bad track. Is there a way to specify how long it will attempt reading a bad track or bad disk? I'm using a Bravo II, not sure if that matters.
  • MTWolf
    • Mar 2011
    • 50
    Re: Is there a way to control how long Batch Ripper will try to read a track?
    Start CD Ripper, Goto the Options Button in the tool bar (Next to Meta), Ripping Method - Secure, Secure Settings, About half way down - Secure Rip Abort, you can set options for max time, max errors, max Re-rip.
