Need Naming String to Prevent "Unknown Artist"/No Metadata Rips from Overwriting
  • jsouza
    • Mar 2016
    Re: Need Naming String to Prevent "Unknown Artist"/No Metadata Rips from Overwriting
    Thanks for the response. I'm glad that you will be addressing the overwrite issue in R16. Instead of adding this with a DSP effect, it would be really nice to have a setting instead. This setting, if set, would completely disable overwrite. I'm wondering in the meantime if marking all of the converted files as Read-Only in the filesystem would prevent the overwrite, but still allow the conversion to continue?
    Also, any plans to address the "suspend machine when conversion is complete" issue that I also mention above? Thanks. FYI, I am a registered user. Sent my payment a couple of days ago.
      R16 should fix the suspend issue also.
      • Organroxx
        • Nov 2019
        I am really sorry.
        I tried this Naming String proposed by Spoon;
        [IFVALUE]album artist,[album artist],[IFCOMP]Various Artists[][IF!COMP][artist][IFEQUALS]artist,Unknown Artist, [cddb_id][][][]\[album]\[track] [artist] - [title]
        to prevent overwriting when you have several "unknown album".
        It doesn't work. It's not creating different folders.
        Can somebody help?
        Thanks!
          Do you have unknown album and unknown artist? Provide a specific example of a cd that causes this problem along with the metadata.
          • Organroxx
            • Nov 2019
            Yes unknown album + unknown artist, so no metadata at all.
            This is what I found, hope it make sense to you.
            dBpoweramp Batch Ripper
            Batch Name:
            Batch ID: 50006
            Using Profile: (default)
            Batch Rip Started: 30/11/2019 15:14:26
            Disc 1: <no meta data>
            Track 1 Result: AccurateRip: Not in database Secure: Yes [05604F7A]
            Track 2 Result: AccurateRip: Not in database Secure: Yes [332C2F9E]
            Track 3 Result: AccurateRip: Not in database Secure: Yes [AB901B16]
            Track 4 Result: AccurateRip: Not in database Secure: Yes [74315259]
            Track 5 Result: AccurateRip: Not in database Secure: Yes [54E6C746]
            Track 6 Result: AccurateRip: Not in database Secure: Yes [C8008608]
            Track 7 Result: AccurateRip: Not in database Secure: Yes [368E3BBB]
            Track 8 Result: AccurateRip: Not in database Secure: Yes [EC9B29C8]
            Track 9 Result: AccurateRip: Not in database Secure: Yes [A5732AA7]
            Track 10 Result: AccurateRip: Not in database Secure: Yes [C1FBFCD7]
            Track 11 Result: AccurateRip: Not in database Secure: Yes [8872DD07]
            Track 12 Result: AccurateRip: Not in database Secure: Yes [18CB79B3]
            Combined Result: All (12) Secure
            Disc 2: <no meta data>
            Track 1 Result: AccurateRip: Not in database Secure: Yes [D3403115]
            Track 2 Result: AccurateRip: Not in database Secure: Yes [CAFD5312]
            Track 3 Result: AccurateRip: Not in database Secure: Yes [7D347934]
            Track 4 Result: AccurateRip: Not in database Secure: Yes [4FA33A15]
            Track 5 Result: AccurateRip: Not in database Secure: Yes [64F9D7BE]
            Track 6 Result: AccurateRip: Not in database Secure: Yes [BA590983]
            Track 7 Result: AccurateRip: Not in database Secure: Yes [6C9CA525]
            Track 8 Result: AccurateRip: Not in database Secure: Yes [3F77D178]
            Track 9 Result: AccurateRip: Not in database Secure: Yes [66F51A68]
            Track 10 Result: AccurateRip: Not in database Secure: Yes [16375C9A]
            Track 11 Result: AccurateRip: Not in database Secure: Yes [1A811077]
            Track 12 Result: AccurateRip: Not in database Secure: Yes [6DA5F32B]
            Track 13 Result: AccurateRip: Not in database Secure: Yes [AA27FB30]
            Track 14 Result: AccurateRip: Not in database Secure: Yes [BCFDF44E]
            Track 15 Result: AccurateRip: Not in database Secure: Yes [1C2AA58C]
            Track 16 Result: AccurateRip: Not in database Secure: Yes [E4DBE9D1]
            Combined Result: All (16) Secure
            Unable to locate Nimbie, is connected?
            Batch Ended: 30/11/2019 15:32:24
            Ripped: 2 Discs
            Rejected: 0 Discs
              Re: Need Naming String to Prevent &quot;Unknown Artist&quot;/No Metadata Rips from Overwriting
              If both those items are unknown, it is not clear to me how dbpa would know to keep them separate. Looks like you are using a batch ripper. For these unknown CDs, I would do them manually and enter some sort of album and artist name. I use following string, but may not help with everything unknown.
              • Organroxx
                • Nov 2019
                Yep. It's a Nimbie Batch ripper.
                I'll try your solution and let you know.
                Thanks!
                • Organroxx
                  • Nov 2019
                  Hi Garym,
                  I'm sorry but your formula is not creating separate folders for "unknown albums or artists".
                  So the second "Unknown" one will overwrite the first one.
                  I guess this is a typical problem for a batch ripper.
                  I can't imagine I'm the only one.
                  Thanks a lot for responding!
                    If both artist and album are unknown, I cant imagine any automatic solution. At least one of those items needs to have some info entered. You likely have to deal with those one at a time in some manual way. I do not use the batch ripper, but I recall discussion of using a DSP to reject ripping under specified conditions. I assume all unknown could be such a condition.
