Post-rip work: batch renaming
  • winopener
    • Oct 2009
    • 23
    I have started to rip my cd collection after replacing the Teac drive (tray locking problems... ended up with a TSST S182, good ripper, same form factor and tray compatible with the extra saw-work for adaptation to the Kodak Kiosk mechanism - highly recommended).
    Alphabetically one of the first discography to pass the rip was the Beatles one.
    However, the ripped files ended up in three different folders, following the Metadata found:
    Beatles
    Beatles, The
    The Beatles
    I can organize manually the folders to have it on just one, "Beatles", however the tags in the single-flac-file and cuesheet will reflect the original mess.
    There is a kind of "batch renamer" in order to uniform the tags between the various flac/cue pair without doing everything by hand one by one?
  • EliC
    • 1175
    Re: Post-rip work: batch renaming
    This is exactly why I am hoping the next version of dBpoweramp can check the artist names already used and utilize the musicbrainz alternative names list to compare and only use one consistent name.
    • winopener
      • Oct 2009
      • 23
      So... seems there is no option at present time?
      • EliC
        • 1175
        I don't use dBpoweramp for tag editing, but you should be able to select multiple files and change the artist in all of them at once.
