Problem ripping severel cd eith no Meta data
  • Rodrigosg
    • Jun 2009
    Hi, i have a Sony Vaio VGP-XL1B and i'm trying to rip about 40 cd's.
    The problem is that much of the cd's have no meta data and when the ripping occurs the Batch Ripper set's a folder 'Unknown Artist\01- Track01' for the first cd and for the second it simple override the info, it should duplicate the info i think?
    Can anyone help me, what should i change in the settings to this thing stop doing this?
    Re: Problem ripping severel cd eith no Meta data
    You can set the Tag Mappings option so when
    IF Artist=Unknown Artist
    SET Artist=Unknown Artist [unqiue]
    • Rodrigosg
      • Jun 2009
      can you give a example, i haven't found those options!! only the [unique] option.
        See the batch ripper help file for details on Tag Mappings.
        • Rodrigosg
          • Jun 2009
          My problem was getting to the Meta options in the Batch Ripper. Thanks for the quick anwsers and for the help.
            Batch Ripper >> Meta Button >> Tag Mappings >> Edit
            • Marc779
              • Nov 2008
              • 17
              I have the same problem. Is there are easy way to have the author and artist "saved" so it doesn't have to be re-enter for every disc?
                With Batch Ripper?
