dBpower AMP 2.0 (..encountered problem...)
  • IM1EAGLE1
    • Dec 2005
    Windows XP
    (Send Error Report)
    Error message content.
    Amp.exe
    Amp.exe has encountered a problem and needs to close.
    We are sorry for the inconvenience.
    (Etc, etc, etc.)
    Data this Error report contains
    Error Signature
    AppName: amp.exe AppVer: 4.0.2.0 ModName: amp.exe
    ModVer: 4.0.2.0 Offset: 000252b7
    (The rest is standard includes Reporting details)
    I have uninstalled (Everything) and re-installed 3 times (including my 'Registered' PowerPack Music Converter, all additionally installed codecs (everything). Nothing works that requires playing my music files with dAP. Please, please help!!!
    IM1EAGLE1 :cry:
    Re: dBpower AMP 2.0 (..encountered problem...)
    Try running the routine here to restore your original settings:
    Even better would be to upgrade to the current beta version of dAP (version 3.6)
    available here:
    If this continues to ocur, can you tell us more about the circumstances in which these crashes occur (formats of the files you are trying to play, whether these files will play in other programs, the frequency, number of channels, bitrates of the files you are trying to play, whether these happens with one, a few, many or all files).
    Bill
    • IM1EAGLE1
      • Dec 2005
      :smile2:
      Follwed instructions to delete registry entry and dBpower
      Folder (C:\Programs\Illustrate\dBPower)
      Note:
      Folder contained my dAPKeyControl.dll
      (Mp3 license that cost me $ 14.00 - Whew!!!)
      (Which fortunately would not delete.... BECAUSE I ...Duh still had folder open)
      I saved by dragging to my desktop and after installing my
      Music Converter I drug it back there before installing the
      dAP-r3- beta6 you provided link to which I had found
      shortly after registering/posting. I configured to my
      liking and restarted my computer.
      EVERYTHING works great again!!! :smile2:
      Just wanted you to know that this problem occured right
      after I started uninstalling bad skin from a "Skin Designer" - 'Nikesh' he called softskin. I got it pretty hard.
      Thanks Again
      IM1EAGLE1
        Thank you for the report. I have not had any problems with Nikesh's Soft skin myself. There could have been a faulty download perhaps.
        The first link I gave for re-setting dAP (dBpowerAMP Audio Player) will clean dAP's registry but should not require you to enter the registry yourself. It's way more painless than the same operation in dBpowerAMP Music Converter.
        In any case, I'm glad you have things working again.
        and Happy New Year,
        Bill
