-??-??- At a Loss -??-??-
    I- d/l'd db power and the codec to make mp3pro files. I also activated the free trial of power pak. I did what the instructs said to do but when i go to encode a file(wav) its encoded to a standard mp3, not an mp3 pro file. How can I tell if its an mp3 pro file? And how do I encode it to mp3pro format?
    If you hold the mouse over the file it should say mp3pro as the encoder type.
      Message to "SPOON"
      It says its a winamp media file type, How do I encode it to mp3pro?
        I meant hold the mouse over the file to get the yellow info tip.
