Volume control
  • apechimp
    • Dec 2005
    Volume control
    When I run dBPowerAMP the volume hot-key on my keyboard controls the dBPowerAMP volume, not the master volume of my computer. It continues to not control the master volume even after I close dBPowerAMP. Is there any way to make it not do that?
    Re: Volume control
    There is a dll you can delete, off the top of my head it is dapkeycontrol.dll from the dbpoweramp folder, that will disable dbpoweramps volume control from keyboard.
    • apechimp
      • Dec 2005
      Re: Volume control
      that worked, you are my hero
