itunes crashes audio player
  • QuadraDuce
    • Jun 2002
    • 16
    After installing Itunes that came with my Nano the db player is now failing to work.
    When I start the player, music starts, systray icon appears, but the skin fails to appear and then Windows has to close the program.
    (Dell 8100/Windows XP Home)
    MP3 Icons in the Itunes folder are Itunes, in other folders they are still db's icons. I have tried to re-associate back to db by way of db's program, then the windows way and then I re-installed the db player.
    The problem persists! Any suggestions?
    ~QD
    Re: itunes crashes audio player
    Your using the latest beta version, dAP r3b6, I believe? If not, install it, as it includes many bugfixes.
    When it crashes, is it trying to play a file?
    Also, try running the dAP reset program here: http://forum.dbpoweramp.com/showthread.php?t=403
