Control Freak shutdown files
  • JTuttle
    • Mar 2005
    • 15
    I have been using control freak and it works great except for a couple of problems.
    After using the "shutdown dap" file, the next time dap is run it will start and then close immediately.
    When using the "shutdown computer" file, windows shuts down, but before it is finished an error from dap comes up.
    If anyone could help me fix these two problems, that would be .
    Re: Control Freak shutdown files
    Perhaps the two are related, what is the error shown?
    • JTuttle
      • Mar 2005
      • 15
      The error that I get when using the "shutdown computer" file is the basic windows error box with "close" and "details" buttons. I think all it says is "This program has caused an error and will be shutdown."
        Sounds like something is stopping dap closing normally, I supose it would crash also if closed manually
        • JTuttle
          • Mar 2005
          • 15
          I never get an error when closing dap manually.
          Maybe it has something to do with windows and dap shutting down at the same time?
