*.ACT format
  • Pico1965
    • Oct 2005
    • 8
    *.ACT format
    Is the format support by the program and/or by dbpoweramp converter ?
    P.S. Is a voice format file used in my MP3 player/recorder
    Re: *.ACT format
    As far as I know, dBpowerAMP does not provide support for the .act format.
    If there is a WinAmp plug-in, you might be able to use that with the dBpowerAMP WinAmp Plug-In decoder.
    Otherwise, you should find some resources for converting your .act files to .wav or .mp3 here: http://filext.com/info/showthread.php?t=156
    Bill
    • Pico1965
      • Oct 2005
      • 8
      Re: *.ACT format
      Thanks for your answer.
      The soluctions I find here before yor reply don't work.
      • Wayne
        • Aug 2002
        • 1254
        Re: *.ACT format
        What model MP3 player/recorder is it?
