Problem with skins
  • Pico1965
    • Oct 2005
    • 8
    Problem with skins
    Hi !!
    I don't want the defauklt skin of program.
    I change it to another skin.
    Why at every restart of the program incoming whit the default skin ?
    Tanks
    Re: Problem with skins
    If you don't want to load a particular skin, enter the dAP Options Menu (open dAP and either click on the button for the Options Menu or right-click on any inactive part of the skin), select Skins, and uncheck the skin you don't want to use.
    You can also either select a particular skin that you do want to use (by unchecking every skin except the one you want to use), or you can arrange to have a random skin appear (from the list of those you have checked) either every time you start dAP or every so many minutes of playing time. You do this by clicking on the correct dot on the Skins window through the Options Menu.
    Of course, you can only use skins you have downloaded and installed (or created yourself).
    If you have tried these steps and you still are having these problems, or if these measure do not work for you, please let us know.
    Bill
    • Pico1965
      • Oct 2005
      • 8
      Ok. I've understood and work good.
