Audio Player hangs on end of track
  • Lt.Worf
    • Sep 2005
    • 33
    I use "My Music Collection" to play my songs (FLAC1.1.2) and enabled "Random" and "Selectiv PLay".
    Sometimes playing stops/hangs at the end of a track -
    in "Audio Player"(V2.0, FLAC-PluginV5.2) the time display 'jumps' between 7:50 and 3:49 (example).
    If I stop and play the song again its o.k.
    What is the problem ?
    • 46220
    Re: Audio Player hangs on end of track
    Turn all crossfade + gapless options off.
    • Lt.Worf
      • Sep 2005
      • 33
      OK. Crossfade was already off, Gapless was on (80ms).
      I have disabled all now.
      Test is runnning ... :-)
      • Lt.Worf
        • Sep 2005
        • 33
        After some testing now the problem is still there, but it seems that playing only stops after playing a mp3 track (I forgot to say that there are few mp3 tracks in my collection).
          After all mp3 files, or sort of randomly?
          What might those mp3 files have in common spec-wise?
          • Lt.Worf
            • Sep 2005
            • 33
            OK, here is my next test:
            I queued all my mp3 tracks an played them (random on and off) and after each track the player stops.
            Same test with FLAC files is o.k.
            I don't know what is wrong with my mp3s, birate is from 128 to 262kbits/s max (44.1kHz).
            Playing in Windows Media Player is ok.
              Are you using the latest dAP beta? Do you have the latest dMC beta?
              • Lt.Worf
                • Sep 2005
                • 33
                Hello Data, nice to see you again.
                I use Audio PLayer r2 and Music Converter r11.
                  Download the latest dAP beta (r3) and dMC beta(r11.5, pretty much the final release) at the links below.
                  • Lt.Worf
                    • Sep 2005
                    • 33
                    ok,
                    must i uninstall the old version before install the new ?
                      I don't believe so, no.
                      • Lt.Worf
                        • Sep 2005
                        • 33
                        I have installed the latest version and mp3 playing is ok now.
                        But now when moving my mouse the cursor stops for some msec every ~ 2 sec.
                        I looked into taskmanager: and CPU time is over 20% (playing FLAC) now !
                        Playing same track in WinAMP I get ~ 2%.
                        P.S. My System is Athlon64 3200+
                          What settings are you using for your FLAC files? If you picked the highest compression, that might explain it a litle bit.
                          • Lt.Worf
                            • Sep 2005
                            • 33
                            I pick medium (standard) compression.
                            > With player version 2.0 playing was OK.
                            > With Winamp(5) playing is OK.
                            > Even with high compression CPU time must be low with Athlon64-3200+ !?
                            • Lt.Worf
                              • Sep 2005
                              • 33
                              I checked all options and plugins, but no change: CPU time ~ 20%.
                              Now I uninstalled complete Audio Player and Music Converter, deleted all files and Registry settings.
                              Then installed latest versions r3b6 and r11.5.
                              Its OK now ! CPU time ~ 2%.
