system tray icon/window bug
  • Lt.Worf
    • Sep 2005
    • 33
    There is a little bug:
    The window that pops up when you move your cursor over the system tray icon is behind the task bar and all windows, so you can't see it (complete).
    Re: system tray icon/window bug
    With the default skin? (it doesn't do this on mine).
    • donny
      • Oct 2002
      • 761
      I don't know this sometimes happens to me, but then again sometimes it's all right... I sometimes lose the OnScreenControl being on top also.
      as far as I got to the problem it happens when two programs with custom drawing procedures argue about who is on top, and then this happens
        Do you have any wierd software installed, such as Windows Blinds?
        • Lt.Worf
          • Sep 2005
          • 33
          I use default skin.
          Windows Blinds not installed.
            Windows XP?
            • Lt.Worf
              • Sep 2005
              • 33
              Windows XP SP2
                I don't know then, sorry.
                  Does it do it everytime you mouse over it, or just sometimes? I know with me, sometimes it draws under the taskbar, other times above the taskbar.
                    Lt Worf-
                    Have you always had this problem with dAP or has it worked ok before and thn gone bad?
                    If the program has worked right beofre and then gone bad you might try this:
                    Bill
                    • Lt.Worf
                      • Sep 2005
                      • 33
                      The problem occurs always and has never worked before.
                      I have changed some options of the taskbar (always on top, autohide, fix on/off ect.) but nothing worked.
                      I also tested quit all running programs ect. but no effect.
                      • Lt.Worf
                        • Sep 2005
                        • 33
                        http://forum.dbpoweramp.com/showthread.php?t=403 : no change.
                        After complete uninstall and installing latest versions no change.
