Selecting CD Player
  • dgcohen61430
    • Aug 2005
    Selecting CD Player
    When using Audio Converter, I don't see how to select read device. I have a DVD Player, CD-RW writer and external DVD recorder. Converter uses the external, how do I change. Thanks
    Dave Cohen
    Re: Selecting CD Player
    Access each of these through the Audio CD Input. Open Audio CD Input, click on the Button that reads Options. This should show what drive if any you are already set up to read. Although this does not appear to be a menu, click on the line that says CD Drive and you should see a menu of available drives (I am not sure about the external drive but I will be hopeful here).
    Please let us know if you do not see a particular drive or drives listed there.
    Bill
    • dgcohen61430
      • Aug 2005
      Thanks, I looked there before I posted but for some reason missed it. It isn't apparent that it's a clickable item.
      Not only does it show the external drive, but that was the one selected after initial install.
      Dave Cohen
        Hopefully it shows your other drives as well?
        It takes some getting used to to see menus that don't obviously look like menus. Elegance in unexpectated places may not always seem to be a virtue at first glance.
        Bill
