Mp3Pro Decoder
  • SOT
    • Jun 2002
    • 36
    Mp3Pro Decoder
    Hi!!
    I´ve been experiencing a little glitch, which annoyes me quite a bit. When either your stop, skip a track,:( Db takes about 1 second to advance or stop the current track.:( It happens even with Regular mp3´s. I´ve replaced the mp3pro dll with the original mp3 one and everything went back to normal. Is there any patch or tip available to solve this problem:question:
    As far as I am aware this is a limitation of the mp3PRO decoder, nothing I can do.
    • SOT
      • Jun 2002
      • 36
      Can´t you have a Mp3 dll and a Mp3pro dll? What I mean is: When AMP is playing normal mp3´s, use the standard mp3 decoder, and when Amp tries to play a mp3pro, use mp3pro dll, if possible.
        No, the files (mp3 and mp3PRO) are just the same as far as dBpowerAMP is concerned.
