Tray Icon Problem
  • Paul_A/V
    • Mar 2005
    • 28
    Tray Icon Problem
    This is a slight annoyance, not a major show stopper. Windows XP has a feature that hides inactive tray icons to allow for more room on the task bar. Windows XP indicates that the dBpowerAMP Audio Player tray icon does not have a title. I have determined that this leads to Windows XP unable to remember the Notification behavior settings set in the taskbar properties. Every time I run dAP I must right click the taskbar, click properties, click customize next to the Hide icons radio button and reset the behavior to Always Show so that the tray icon does not go hidden. This is obviously a low priority bug. I just wanted to bring it to your attention.
    [FONT=Arial Black]Regards,
    Paul[/FONT]
