Quemaster Fails to Start
  • saulniers
    • Jul 2005
    When I attempt to start Quemaster, the following error block is displayed:
    "Exception EFOpen Error in module quemaster.exe at 00012ADF. Cannot open file Quemaster/history.txt".
    I checked Program Files>Illustrate>dbPowerAmp>Quemaster and found the file history.txt in that folder. quemaster.exe is present in the main folder Program Files>Illustrate>dbPowerAmp
    Re: Quemaster Fails to Start
    Have you been using Quemaster before and this just started?
    Are you trying to open Quemaster through your destop icon or through Start>All Programs>dBpowerAMP>Quemaster.exe?
    What Windows version are you using?
    The locations of the history.txt file and of quemaster.exe seem right. I would recommend trying to uninstall Quemaster (through Control Panel>Add/Remove Programs), reboot and reinstall.
    Hope this helps.
    Bill
    • TarkusShakti
      • Jul 2005
      • 102
      I have a similar problem, in that mine crashes with a "Please tell MS about this problem..." screen. Both this prog and dbpoweramp are installed in the default directory. I have used the desktop icon and the start menu icon.
      I am running a fully patched version of XP. I have uninstalled, rebooted, reinstalled with the same results...
      I am using the latest version of dbpoweramp. Also, I'm a first time user of QueMaster...
      ASUS P8P67 PRO (Rev3.0)(BIOS 1502) ~ Core i5 2500K 3.3G ~ 16 gb G.Skill Ripjaws X DDR3 1600 - Sapphire HD5700 w/1Gb ~ 1 - Corsair Force Series 60 Gb SSD ~ 2 - Samsung HD204UI 2 tb ~ 2 - Samsung HD753LJ 750 gb ~ 1 - Pioneer DVR-212D ~ SeaSonic S12II 520W ~ Lian-Li PC70 ~ I boot Win7 SP1 on this desktop.
      or
      ASUS G71Gx (BIOS 1704) ~ Core Duo P8700 ~ 6 gb DDR2 ~ Geforce GTX 260M w/ 1 gb DDR3 ~ I boot Win7 SP1 on this laptop.
        When you say latest version, do you mean release2 or the latest beta?
        • TarkusShakti
          • Jul 2005
          • 102
          I downloaded a file named QueMasterInstall13...
          or
            I was referring to your version of dAP. The latest dAP beta is linked below. Uninstall QueMaster, install the new dAP, then reinstall QueMaster and try again.
            • TarkusShakti
              • Jul 2005
              • 102
              Oh! Sorry...
              I'm using release 11 of the dBpowerAMP. I didn't realize that quemaster only worked with experimental software. Someone should really note this fact, it might save people some time and trouble.
              Pls forward a "thanks for nothing" to the quemaster author...
              or
                When Spoon releases a dMC or dAP beta, they aren't necessarily what you consider "beta" software. It just means he is adding features and quashing bugs and its not quite ready for an official release, whether due to files needing updating or a few things need fixing.
                I have used the dAP and dMC betas for a good long time and have NEVER had either of them crash on me. We recommend everyone use the beta versions, especially the dMC beta, as there are a decent number of bugs that are fixed and a few new features that are added. Could it hurt to try the betas? If you don't like them, you can always go back to the official release.
                As for QueMaster not working, I just suggested you use the dAP beta, that may or may not fix the problem. I've never personally used QueMaster, so I can't really specifically help if the problem is with that.
                • donny
                  • Oct 2002
                  • 761
                  hmm these problems seem a bit odd... what can I say...
                  no QueMaster should work with any version of dbpoweramp, meaning it shouldn't matter if it's release 3 or release 3 beta6. if this keeps occuring I will have to make a quick patch (like ver 1.3.1 or somtething).
                  I am sorry for the inconvience you experienced with the software. I don't knwo why it whon't load the file, it is only needed in the about box, so I am a bit puzzled.
                  I will do some testing and will let you know.
                  and TarkusShakti, you are "welcome for nothing" ... this program is something I do in my own time, just because I like programming, without any profit, and I'm letting people use freely the software just so that they can use dbpoweramp with more features...
                  • Wayne
                    • Aug 2002
                    • 1254
                    I can report that I have successfully installed and run QueMaster 1.3. I have never had a problem with earlier version either whatever version of dAP was installed.
                    Wayne
                    • Valarauko
                      • Jul 2005
                      QueMaster not working for me either. Wants me to report the error to MSoft.
                      -Latest official dAP release
                      -Windows XP SP2
                      • donny
                        • Oct 2002
                        • 761
                        OK, I will have to investigate more - yes it is a stupid mistake that whe the file is not found it does crash totally and will be fixed, - but it should not happen anyway...
                        try the previous version:
                        I didn;t have much complaints about that one...
                        and you should expect an update in a few days,
                        sorry for the trouble
                        • donny
                          • Oct 2002
                          • 761
                          here is the update I think it will work - test it and let me know...
                          • Valarauko
                            • Jul 2005
                            Well, it does at least start now
