Can dAP work with Logitech iTouch Keyboard
    Yes!, you need release 2 of dAP (at time of writing it is in beta), dAP has to be set to use these default keys (from dAP Keyboard Control config program):
    play X
    pause C
    stop V
    prev Z
    next B
    Then add this line to the iTouch Config (C:\Program Files\LogiTech\ITouch\players.ini):
    Put this in the [Players] section dBpowerAMP=key,amp.exe,dBpowerAMP Audio Player,xxx,xxx,X,C,V,Z,B,0,1,dBpowerAMP
    Save the file and restart iTouch.
    Also if you want dAP to start when pressing a key add:
    Code:
    [HKEY_CURRENT_USER\Software\Logitech\iTouch\CurrentVersion]
    "MediaPlayer"="C:\Program Files\illustrate\dBpowerAMP\amp.exe"
    to the registry.
    [SIZE=1][totalXSive: editing to make slightly clearer ][/SIZE]
