Player Volume slider is lowered by itself
  • jfkaess
    • May 2005
    • 119
    I'm playing through ail my tracks in MMC (all are set to automatically adjust volume boost).
    Occasionally, for some unknown reason and with no interaction on my part, the volume slider on DAP will be moved to the left lowering the volume. It never resets after playing other tracks. The volume boost setting does not seem to be effected, but yet, the player volume is effected.
    I would suspect this is some type of bug? I'm using the latest beta of DAP and dMC.
    (I know I seem to be asking a lot of volume questions).
    Re: Player Volume slider is lowered by itself
    The volume boost does not change the main volume control at all (it is all done internally).
    • jfkaess
      • May 2005
      • 119
      Any idea what is changing the volume control on the player? I know it isn't me - I leave it playing set on maxc, and come back an hour or tow klater and its at about 870% of max, and I didn't touch it
      • Craze
        • Oct 2002
        • 308
        Change AMP settings to DirectX.
        Right click anywhere on dAP to get a menu, or press a menu button from default skin or from within MMC,...select AMP,...click on DirectX.
        • jfkaess
          • May 2005
          • 119
          Already set that way. I made that change when i installed because I was getting noise during play back and making that change fixed it.
