Arg - Problem with MMC and dAP - for iTunes protected files
  • 4x4Grimreaper
    • Jun 2005
    • 10
    Re: Arg - Problem with MMC and dAP
    Originally posted by ChristinaS
    Are all the audio files you're trying to play in dAP of audio types for which you have the codecs installed in dMC? are any files protected - like in iTunes protected files?
    Yes there are iTunes protected files, but I haven't tried playing them yet...
    I'll probably convert them into some other format.
    EDIT: How do I play iTunes protected files(ones that someone sent to me)?
    • 4x4Grimreaper
      • Jun 2005
      • 10
      Is anyone going to answer my question?!
        If you are not the original buyer of those iTunes files you cannot ever play them or convert them. The same thing aplies if the files were bought by you but you moved them to another computer. They are useless to you now. They only work on the original computer where they were downloaded as this is where the licenses are stored. And, no, you can't hack them in any way.
        The person who gave them to you should have had them converted in the first place and given you unprotected versions.
          Information for converting iTunes songs you downloaded would be found in the "DRM and Copy Protection" section of this forum. Note that protected songs a friend sends to you are worthless.
          Any other problems?
          • 4x4Grimreaper
            • Jun 2005
            • 10
            Nope.
