MMC and Track # Field
  • gab
    • May 2005
    • 18
    I'm having trouble with the Track # field in MMC. All my tracks are misnumbered by 1. For example the first track in every album has no track number, the second track is nymbered #1, the third track #2, etc...
    Any idea what I'm doing wrong?
    Re: MMC and Track # Field
    WMA tracks?
    • gab
      • May 2005
      • 18
      Yes WMA Lossless tracks. Sorry for not including in the original post.
        What created the files?
        • gab
          • May 2005
          • 18
          I ripped and encoded the tracks using WMP10. As I noted in my first post, other media players don't have a problem. Also the track numbers are part of the file name (don't know if this matters)
            and you are using the latest dbpoweramp wma codec?
            • gab
              • May 2005
              • 18
              I think so however I'm not 100% sure. There's a chance I'm using v9 because I'm not sure how long v9.1 has been on Codec Central. When I get home tonight, I'll download v9.1 and see if it works.
              • gab
                • May 2005
                • 18
                I downloaded the latest WMA codec and it still doesn't work. The track numbers arel all off by one.
                  Check your WMA tagging options. Try setting it to "WM/TrackNumber & WM/Track"
                  • gab
                    • May 2005
                    • 18
                    Sorry for the dumb question, but how do I do that?
                      Go into dMC Configuration (Start --> Programs --> dBpowerAMP Music Converter --> Configuration --> dMC Configuration). Depending on your version, you either have a "ID Tagging Options" tab or a "ID Tag Options" button. Click on the button/tab and see what the setting for WMA is.
                      • gab
                        • May 2005
                        • 18
                        Thanks. I'll give it a try when I get home tonight.
                          I think that is just for tag writing. I will note this as a bug to be looked at.
                          • gab
                            • May 2005
                            • 18
                            Did this ever get looked at? I REALLY want to use MMC because I love the other products.
                              It is next in line for a bug to look at (currently looking at flac tagging issues).
