Player Stops
  • yesila
    • Mar 2005
    • 8
    Player Stops
    Just recentlly downloaded dBpoweramp and am experiencing baby-sitting problems. Specifically I have it play on random and after a few songs played it does not advance to the next song it just sits there at the end of the last song waiting for me to hit the skip button. Any ideas of how to fix this?
  • yesila
    • Mar 2005
    • 8
    Re: Player Stops
    No ideas?? any menus that i might be missing where i have a setting borked? What appears to be happening is the player occasionally stops in a loop of the last 1sec of a song. Most of the time this seems like a stop, but the other day it happened on a song that had a sound in that last sec so it looped that and i got my "record skipping" sound. anyhelp?
      Re: Player Stops
      What version are you using? Release 2 or the latest Release 3 beta?
      • yesila
        • Mar 2005
        • 8
        Re: Player Stops
        I'm using release 2.
          Re: Player Stops
          Try getting the latest beta from the link in my signature.
          • PollieXmas
            • Apr 2005
            • 10
            Re: Player Stops
            I was experiencing the same problem.
            After the upgrade to the beta I have not had the problem again.
            Thanx
            Paul
            • yesila
              • Mar 2005
              • 8
              Re: Player Stops
              I got the beta the other day and have not experienced the problem again either. I had previouslly looked through the beta thread and didn't see a fix put in there for that problem. I guess it was just a general stability issue. Thanks for the advice LT. Data.
