Musepack codec configuration
  • Paul_A/V
    • Mar 2005
    • 28
    I am experiencing a problem with the Musepack configuration settings in the Multiplayer menu. I find that any changes made to the settings are not saved. After clicking OK and then opening the dialog again it shows the default settings and not the settings I previously made. What is going on here?
    [FONT=Arial Black]Regards,
    Paul[/FONT]
    • 46220
    Re: Musepack codec configuration
    There is a new mpc codec that works natively in dbpoweramp it is in codec central (it will not have all the plethora of tweaking options), but it will work better with mpc.
    It is in the beta section of this forum.
    • Paul_A/V
      • Mar 2005
      • 28
      Thanks Spoon. I am curious, are there improvements in audio quality? Should I go back and rerip my CD collection?
      Paul[/FONT]
        • 46220
        No improvements in the encoder (maybe small bug fixes).
