Having problems with long tag title names
  • Smoggy
    • Feb 2005
    • 120
    The title tag is getting cut off when I import songs with long names into WinAmp 5 and WMP10
    When I check the tag properties using BdpowerAMP the complete title is there and it says the tag is APEv2 & ID3v1 & ID3v2.3
    When I check the tag (using winamp) the name is cut short and also says ID3v1 ID3v2.
    Can anyone tell me how to fix this??
    Does DBpowerAMP always write ID3v2 tags?
    Win XP Pro
    Winamp 5.0
    Smogg
    Re: Having problems with long tag title names
    Go through dMC Configuration and change any ID Tag Creation settings as needed.
    • Smoggy
      • Feb 2005
      • 120
      The only configuration setting I can find is under Options "Write ID tags" check mark for on or off. Can you tell me where to look for ID Tag settings?
      Thanks!
      Smogg
        Thanks!
        Not in dMC Audio CD Input Options.
        Look in:
        Start > Programs > dBpowerAMP Music Converter > Configuration > dMC Configuration.
        • Smoggy
          • Feb 2005
          • 120
          Got it thanks!!!!!!!!!!!! :komisch9:
          Smogg
