Ability to Edit
  • KunkleMan
    • Mar 2005
    Ability to Edit
    Have d/l Release 2 several times and cannot edit title,artist, etc. Am I missing something? I don't see where anyone else is having this problem.
    There is no "OK" at bottom of window to confirm changes. Help!!
    Ok, thanks for leading me to prior post on this. See problem.
    Re-edit---Spoke too soon. I see nothing in configuration which allows me to edit tags. I need educated.
    Re: Ability to Edit
    So you ran dMC Configuration and checked the boxes appearing at the bottom of the screen referring to Windows Shell Integration? If you did, then when you are in Windows Explorer and right click on an audio file which has the ability of having tags (i.e. not a wav, not a meta-file either), then you get the option to Edit Tag. You can also edit tags by a right click and selecting Properties and from there ID Tags, if you OS supports that - XP and WIndows 2000 both do, not sure of others.
      Re: Ability to Edit
      dBpowerAMP Music Converer or Audio Player?
      • KunkleMan
        • Mar 2005
        Re: Ability to Edit
        Audio Player
        • Craze
          • Oct 2002
          • 308
          Re: Ability to Edit
          Not sure if this is what you're asking...
          But to Edit Tags from the player, open MMC and right click on any file you want to edit the tag from. You should get a menu similar to the snapshot I've attached. Click on Edit Tag and get the "Editing" screen. Click "OK" when your done.
          Hope this is helpful.
          -Craze
