Problem arises again !
  • Cheenix
    • Jan 2005
    • 10
    Posted previous problem being unable to copy across wma files using philips 120 driver, I thought I had the problem fixed but it has occured again, the actual error message is as follows
    Unable to send 'C:\DOCUME~1\Cheenix\LOCALS~1\Temp\Svt1.tmp\Soft Rock Anthems CD1.wma' to portable player. Please check connection and player has free memory.
    The player is on through external power and plenty of space, Any ideas ?
    • 46169
    Re: Problem arises again !
    Same message if you try a different file?
    • Cheenix
      • Jan 2005
      • 10
      Yes, But before I get that message the following appears
      Support the audio type '.' might be obtained @ codec central, visit codec central now
      when i click yes the previous message appears and nothing happens, Tried installing codec files again and same message .
        • 46169
        that is a known bug (if copying a folder to the HDD from Sveta Explorer), is that what is happening?
        • Cheenix
          • Jan 2005
          • 10
          Yes, Any soloutions ?
            • 46169
            Use 'File Selector' to send folders instead (not Sveta Explorer), you can find it in the start menu >>
            • Cheenix
              • Jan 2005
              • 10
              Do you mean explorer ? , I dont seem to have file selector under my start menu. Running Windows xp pro ?
              Sorry If I am being Dumb.
                File Selector is one of the programs that gets installed when you install from the dBpowerAMP Music Converter program. Look for it in Start > Programs > dBpowerAMP
                • Cheenix
                  • Jan 2005
                  • 10
                  Dont seem to have that program, but i do have the convert program, Am I needing to see my shrink again or just being dumb ?
                    Are you using dMC Release 11? If you are, you should have file selector. If not, before Release 11, File Selector was a separate download.
                    If you ARE using Release 11 and still don't have file selector, you might need to reinstall dMC.
                    • Cheenix
                      • Jan 2005
                      • 10
                      Ok, Thanks for the help But, There is always a But, I have downloaded and installed and have the file selector part of it, I dont seem able to copy the folders to portable or even H drive without converting the files. They are already converted and just want to move them to portable. Sorry for the stupid questions.
                      • Cheenix
                        • Jan 2005
                        • 10
                        Happy Days are here again, Found solution by trial and error.
                        A big thanks for everyones help.
                          • 46169
                          For others reading the likely solution was 'Smart Conversions' to set the audio to download without conversion.
