question on 24 bit wav
  • savagcl
    • Aug 2004
    • 439
    Was just over at winamp site and posted a msg about 5.1 channel sound.
    I have a PCM WAV file, 6 channels, 24 bit, 44100 and it plays well under
    dBpower player, Creative player and WMA. but Winamp only gives noise
    as output.
    Anyway, the question: Other than the tag (which is only a file description),
    how is it possible to tell if you are really getting 24 bits throughput?
    (even DSP to 16 dither - from the name i'm assuming its reading 24 bits
    but changing to 16 bit on output)????????
    Interestingly enough, there is a thread at winamp discussing that creative
    cannot play 24 bit as it claims which equals false advertising in my book.
    There is also a partition with over 7000 signatures asking creative for
    better support, etc, etc. I signed it.
    thanks,
    savagcl
    Re: question on 24 bit wav
    There is no way finding which output bit count is being used in dAP, it should show something somehow though...will add it to a wish list.
    • savagcl
      • Aug 2004
      • 439
      Thanks, Spoon.
      I know the plate in front of you is full but this would help.
      savagcl
