File name problem: Seeing all ripped tracks
  • brds16
    • Sep 2004
    • 13
    I am using dMC Audio cd input to rip. I have set my dMC-Audio CD Input Options - File Creation to read [track number xx][album]. When I rip, I see the progress indicating that all tracks are being ripped but when I open the folder, I only see the last track. What should I be doing differently?
    Re: File name problem: Seeing all ripped tracks
    Try ripping again. Make sure all tracks are checked in the Audio CD Input tracklist prior to ripping. I have had occasions where I will not catch that all not tracks were checked before I ripped.
    The second thing you might do is to open up the folder you are ripping to. You should be able to see each file as it is being added.
    I trust that the one track you saw was, in fact, just the one track and that you did not mistakenly use "rip as one" (which requires the Power Pack and has a whole different screen). But I would check your one track just to make sure.
    Hope these ideas help.
    Good luck and best wishes,
    Bill Mikkelsen
      Do a 'rip with options' then click 'rename' to see the filenames it will use.
