24-bit DSP plugin
  • Brian49
    • Sep 2004
    • 28
    24-bit DSP plugin
    Hello. I can't figure out in which folder to install the 24-bit DSP plugin so that it becomes available in the DSP configuration window. Can anyone advise me, please? I'm running release 3 beta 5 of the player. Many thanks.
    Re: 24-bit DSP plugin
    I have never had any problems installing dB programs, modules, codecs, whatever, to their default location. The 24 bit DSP plugin is a DSP for the audio player only. You will not see it in your list of DSP effects for Music Converter.
    Bill Mikkelsen
    • Brian49
      • Sep 2004
      • 28
      Sorry, I think you've misunderstood me - I'm referring to the DSP config window in the player, the one that comes up when you click on the plugins item on the options menu. The 24-bit plugin isn't visible there, which I presume means it's in the wrong folder. Where exactly should it go, please? I have the player installed in C:\Program files\dbPowerAMP\Player. Many thanks.
        • 46220
        Install the DSP effect to the same location as the amp.exe
        you might also need the latest beta version of dap.
