XP SP2 problem?
    • 46220
    XP SP2 problem?
    I am having a problem with dAP after installing SP2, the problem is if the computer is hibernated whilst playing through dap, after the restart dap takes 100% of cpu time and will freeze after the track has played.
    Anyone else seen the same?
    Terratec Aureon Space 7.1
    Using 24 bit dsp effect
    Playing Monkeys Audio Files
    Re: XP SP2 problem?
    I don't have SP2 yet. I have heard there are a rash of problems with it vis-a-vis a number of programs. If you have not already done so you might want to check out the following thread from Microsoft's Knowledge Base:
    Bill Mikkelsen
      • 46220
      Re: XP SP2 problem?
      Put it in the debugger and it was a rouge DSP effect - the Remote Control, that no one will be using anyway, case closed.
