attaching skin to tray control
  • Nikesh
    • Jan 2003
    • 24
    I found that I am not able to make tray control with two skin windows.
    If I hold mouse pointer over the attached skin the tray control scrolls down. There is a button which toggles the display of this skin (User evt). So i cannot make it 'Show While evtdB TrayControl'. Is there any way I can solve this problem?
    [B][COLOR=DarkOrange]Nikesh[/COLOR][/B]
  • Craze
    • Oct 2002
    • 308
    Re: attaching skin to tray control
    You can have two or more skins in the Tray. They all have to have the same command Show While: evtdB TrayControl... unless you have another means of displaying the skin such as a button (with a USERevt), or a skin tab.
    You may just want to reset the Tray to Show Position: Last Position. That would keep it from scrolling.
    Otherwise you might check:
    Z Order. Make Tray the highest value (i.e., Tray=2, Attached=1.)
    Check box "Top Most" on both skins.
    Assign the attached skin to Show Position: Locked to Primary Window
    Hope this is helpful.
    Craze
    • Nikesh
      • Jan 2003
      • 24
      Thanks Craze. But it didn't work. I did everything like u said. Making the tray appear at last position didn't help b'coz the it didn't scroll down, but disappeared. Problem is attached skin is not treated as a part of tray control.
      • Craze
        • Oct 2002
        • 308
        Explain a little more about what you are trying to do. I don't seem to be following you. But will be glad to help if I can.
        • Nikesh
          • Jan 2003
          • 24
          My tray control is made of two parts(skin windows). Main part is set to show while 'evtdBTrayControl' & other part appears when I click a button on the tray control [COLOR=Gray](I have set it to appear over the tray control as a part of it - it's a color change)[/COLOR]. The problem is when I hold the mouse pointer over the second skin which is set to show while 'UserevtShowtc' [COLOR=Gray](toggled by a button on tray)[/COLOR] the tray control scrolls back as if I am not pointing over it. Hope it's clear now.
          Have u ever tried to make a sliding window or something for the tray?
          Did it work?
          • Craze
            • Oct 2002
            • 308
            I've never tried this and I can't recall any skin having this option on the Tray, but it still ought to be possible. The Default Mini basically does this.
            I'm away from my pc currently, but what I might try is to reset how the Tray displays so that you can at least keep it from scrolling down while you are working on it.
            Instead of Show While: Centered Over Mouse, change it to :Last Position
            The disappearing problem sounds like the ol' bug issue some are having with the Tray Control depending upon which operating system you are using. http://forum.dbpoweramp.com/showthread.php?t=5247
            See post #13 for my test results.
            You may have to click on a blank area on your taskbar or near your clock in order to get the Tray to display correctly.
            I'll try to make a slideout for a Tray when I get time and see if I can help you figure it out.
            • Nikesh
              • Jan 2003
              • 24
              Hi Craze,
              Thanks for your response. I don't think it's a bug. It's rather a lack of feature i suppose. But that's not very important. I just wanted to switch between two colors in the skin. i did this successfuly in the main amp. I am posting the skin to spoon now.
              Will it be trouble for spoon if I am sending him many skins?
