CD Input won't see drive
    My CD Input used to see my drive, but hasn't done so now for ages. If I enter options and click down CD Drive ADVANCED menu there is nothing in the drop down. I have one CD drive and it runs as G:
    WMP, Real, CD Ripper all see the drive. but its db I want to use!
    Any ideas?
    fatgarth
    Re: CD Input won't see drive
    You may want to try the advice in this thread here:
    If you have already tried this, could you please give some specifics about your system and about what versions of dBpowerAMP you are using (and which programs-I note that you have posted this as a problem for dAP (the dBpowerAMP Audio Player) but your reference seems to be Audio CD Input (which is a component of dMC the Music Converter program).
    Bill Mikkelsen
      Xoas,
      thanks for the assistance.
      <i>"your reference seems to be Audio CD Input (which is a component of dMC the Music Converter program). "</i>
      That will explain why I couldn't find an appropriate thread among the 250 here! :")
      Yes, its the Audio CD input as part of the converter. I'm using it on WinME.
      The version is dMC-r10
      Fatgarth
        Not an uncommon mistake.
        If the advice in the thread does not work for you (or if you should have other problems/questions), please let us know.
        Bill Mikkelsen
          Found the advice and now sorted. Many thanks.
          FG
