Volume Control
    Volume Control
    Hi!
    Not sure if this is a bug or an intentional thing but when running dBpowerAMP player I find it takes control of the volume buttons on my keyboard. This is ok in a way, except while it is running they only adjust the wave volume, not the master volume.
    And then when I close dBpowerAMP, either control does not return to the master volume control or they stop working altogether, which is extremely annoying!
  • donny
    • Oct 2002
    • 761
    Re: Volume Control
    search the forum for similar posts.... this has been talked about many times... and there are diferent solutions depending on what you really want....
