Offline FreedB
  • Paddy
    • Jan 2003
    • 71
    Offline FreedB
    A thread was posted a few weeks back about using FreedB without internet connection. I downloaded the database and set it up with DMC so it automatically sets the track titles from the offline Database, It makes ripping CD's extremely quick :D
    Problem is I can't get the dBPowerAmp Audio Player to extract the info from the database! If I put the CD in DAP automatically starts but just displays track 1 etc. When DMC is loaded the track info is found, so then running DAP it'll show the info. Is there anyway to change a setting to get DAP to link to this offline DB??
    Cheers
    Re: Offline FreedB
    dAP can only take from CDplayer.ini (ie any cds put into CD Ripper).
